Will a version of the installer be made available that includes HF2?
Or if we want to do a fresh install, do we need to install 2020.2.1 (the compromised version) and then install the hotfixes?
Hot Fix 2 is now available and should be in your customer portal.
not sure is HF2 is already out, but usually, when a hotfix is released, they also update the online and offline installer so that when you do the install, they will be included. You can also tell by looking at the Installation boxes as it will tell you the version and hotfix that will be installed.
I see HF2 in the customer portal.
But there does not appear to be a version combined with the main installer.
Will this be made available soon for a fresh install?
