I'm creating an integration for solarwinds to send alert information to my ticketing system. I'm using a HTTPS POST to an URL as a trigger action and I'm putting various fields into the JSON payload.
But I'm stuck because I need to uniquely idenfity each active alert so that my ticketing system can store the unique alert ID so I can use it in a reset action (the reset action is going to send another JSON payload to my ticketing system and we're going to add some notes to the original ticket that was created).
I think I'd like to use this ID:
But I don't know which variable will give me the "15033" (or even AAT:15033). Which variable is that? Is that variable available to me when the reset actions fire?
Or is there a better variable I should be using?
Thank you
