Hey folks, trying to cram in some research on QoS monitoring toolkits in a hurry. Does anyone who has worked with Solarwinds Netflow Analyzer know if it does PER NODE/HOP QoS analysis? The use case is that we want to run a test on a client's network to test VOIP prioritization through every switch and router between the testing point and the outside world, and have it generate a visual report that xxx router is not properly configured for VOIP prioritization so they know what to focus on. I believe that AppNeta does this, but they're a bit overkill for what we're looking for as part of a temporary toolkit at different locations. We're also looking at LiveAction NX and working with their support on a cloud server installation as another alternative.
Thank you most kindly
I was not looking for the information - I was hoping I could help the user.We use NAT/VNQM (IPSLA) and Netpath. Thanks for asking - But I am good to go for this.
Were you ever able to get this information?
Just thinking out loud here a bit. Have you looked at our Netpath capabilities? Also, our VNQM functionality support IPSLA for Cisco and Juniper RPM for these types of analysis.
Yup, that is the same path or recommendation I would have to this user as well
