We’re happy to announce SolarWinds is partnering with DigitalOcean, a cloud infrastructure provider offering cloud services to help deploy modern apps, to offer application level monitoring to applications running in droplets with SolarWinds
application performance management (APM) solutions.
DigitalOcean offers built-in monitoring capabilities to track infrastructure metrics like CPU usage, disk usage, disk I/O, bandwidth, and memory at no additional charge. But monitoring the DigitalOcean infrastructure only tells half the story; you also need to monitor the applications running on top of the infrastructure. The addition of SolarWinds APM solutions to the monitoring provided by DigitalOcean extends your visibility up to applications and services.
With SolarWinds APM solutions, DigitalOcean users can create application-level metrics, trace transactions, monitor the performance of individual processes, and drill down to poor performing lines of code.
This new combination enables you to monitor, measure, and improve the performance of both your applications, and the infrastructure. With true, end-to-end visibility across applications running in DigitalOcean, you can detect problems early, avoid outages, and improve the overall customer experience.
Learn More
To learn more about DigitalOcean and our partnership check out the SolarWinds partner page on DigitalOcean. If you already use DigitalOcean, try out the SolarWinds APM solutions, Papertrail
, Loggly
, AppOptics
, and Pingdom
and let us know what you think.
