Have a server diagnostics shows there is a logon issue from SolarWinds NOC. All other servers are OK but this one server is causing our SolarWinds server to generate an event id 1000. SolarWinds TS told me the login is failing and needs to be updated. I did so in NOC by going into the Node Details Management then updating the credentials but it still fails. 25 plus other server have no issues except that one.
Was wondering if anyone had any ideas of what I should look at. Appreciate any help. Thank you.
Placid Auguste.
