I need a SWQL to create a table widget to show Top 10 CPU usage and another to show Top 10 Memory usage sorted my highest to lowest.
There is a standard Widget close to your requirements.
is this what you look for or do you need a query to modify?
I want to create. modern dashboard and cannot use the pre build table. will have to use SWQL or SQL
