I'm attempting to follow the information found here: https://support.solarwinds.com/SuccessCenter/s/article/Run-the-SolarWinds-Orion-Installer-in-the-silent-mode?language=en_US#Step1
While it provides some configuration examples it doesn't appear to install the product with the same configuration that I do when I install it manually. I'm wondering if there's a way to derive the configuration file from a manual installation.
For example, if I were to manually install CentOS Linux on a machine, the installer will place a kickstart file in the /root home directory. I can then use this kickstart file to repeat the installation on other machines.
Does SolarWinds have a similar implementation for creating installation configuration files? Also, if my silent install runs into a problem at some point is there an installation log file that I can look at to see where it got hung up?
