I am trying to write a script (not a script guy) for Linux servers (not a Linux guy either) that will return the system uptime for a server. I want to use 1.3.6.1.2.1.1.3.0 which is a timetick OID. I found the following file in the C:\Program Files (x86)\SolarWinds\Orion\APM\SampleScriptMonitors\LinuxScripts directory but cannot get it to work.
When I run it I get this:
Output Result:
Message.Statistic:
Server Uptime at host "c111bexhdd078": (9023307) 1 day, 1:03:53.07
It appears that "something" is automatically reformating the timeticks into DateTime format which is prevent Orion from seeing it as an acceptable statistic. I have hit a wall on this and am looking for some help
#!/usr/bin/perl
# Copyright \xbf 1999-2008 SolarWinds, Inc. All Rights Reserved.
if (@ARGV[0] =~ /\bhelp\b/)
print "ServerUptime.pl SNMPver community hostname\n";
print "SNMPver - version of SNMP protocol\n";
print "community - community name of SNMP protocol\n";
print "hostname - Target host\n";
exit 1;
# Get hostname and trim newline
$localhost = `hostname`;
$localhost =~ s/\s*$//g;
$hostname = shift || $localhost;
$community = shift || "public";
$version = shift || "v1";
$results = "";
$MIB= "1.3.6.1.2.1.1.3.0";
$outres = "snmpget -$version -c $community $hostname $MIB |";
open(OUTSTD,$outres) || die "Unable read pipe\n";
while ($line = <OUTSTD>) {
$indval = index($line,"=");
$indval = index($line,":",$indval);
$val = substr($line,$indval+1,length($line) - $indval);
$val =~ s/[\/\n]//g;
print "Message: Server Uptime at host \"$hostname\": $val\n";
print "Statistic: $val\n";
exit 0;
print "Statistic: 0\n";
exit 1;
