Dear All,
I am getting below issue. I'm assuming this is related to one or more specific nodes.
Does anyone have an idea how to identify which node(s) it concerns (Query, Log file, ...) ?
Part of the Saver error locally output:
Error Instance: fe45304c42af40a3968dbd6c7c847d95
User: cwwpvt\09280934
URL: Orionserver:443/.../rendercontrol.aspx
Referrer: OrionServer:443/.../rendercontrol.aspx
Message: Specified cast is not valid.
ErrorSite: App_Web.orion_netperfmon_resources_summary_problemnodes_ascx.__DataBinding__control10
ErrorType: System.InvalidCastException
Stack:
at ASP.orion_netperfmon_resources_summary_problemnodes_ascx.__DataBinding__control10(Object sender, EventArgs e)
at System.Web.UI.Control.OnDataBinding(EventArgs e)
at System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding)
at System.Web.UI.Control.DataBind()
at System.Web.UI.Control.DataBindChildren()
at System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem)
at System.Web.UI.WebControls.Repeater.AddDataItemsIntoItemsArray(IEnumerable dataSource, Boolean useDataSource)
at System.Web.UI.WebControls.Repeater.PostGetDataAction(IEnumerable dataSource)
at System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource)
at System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e)
at System.Web.UI.WebControls.Repeater.DataBind()
at Orion_NetPerfMon_Resources_Summary_ProblemNodes.Page_Load(Object sender, EventArgs e)
at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at SolarWinds.Orion.Web.UI.BaseResourceControl.OnLoad(EventArgs e)
Thanks much,
John
