I want to be able to send a node custom property as a variable in an interface alert, but I find that if I change the "Insert Variable" menu to Nodes, and then select the Node Custom Property, that it will not display the value in the email that is sent. Will I have to configure a Custom SQL variable to do this, or should I just create an analogous interface custom property and populate it?
If custom SQL is the best option, what would the query be to show, for example, the node cp of "City" in the Interface alert message?
Thanks for nay help
