Hey all,
I've had to create Universal Device Poller to dig further into our SD-WAN appliance's VPN overlay statistics. I've bene able to obtain the data I want via SWQL Studio, however the data in its current form (row data) I’d like to move to columns to neaten up the view (and prevent endless scrolling across 100+ sites).
Below is an example of the data I am getting at the moment, where the “CustomPollerID” column has the info I need (which is readable in the “AssignmentName” column.
Site | Node | DeviceType | AssignmentName | Status | CustomPollerID |
Balsall | BSHC | SD-WAN | VPathName | BSCH-RCN01 | d8208 |
Balsall | BSHC | SD-WAN | VPathState | Good | 18eb3 |
Balsall | BSHC | SD-WAN | VPathBytesSent | 21900544 | b3840 |
Balsall | BSHC | SD-WAN | VPathBytesRecieved | 2195456 | fefda |
Balsall | BSHC | SD-WAN | VPathSentJitter | 10 | 9ffbe |
Balsall | BSHC | SD-WAN | VPathRecievedJitter | 4 | dcfed |
From the above, I’d like to move the common VPathxxxx headings to columns and capture the relevant data for each item if possible?
Site | Node | DeviceType | VPathName | VPathState | VPathBytesSent | VPathBytesRecieved | VPathSentJitter | VPathRecievedJitter |
Balsall | BSHC | SD-WAN | BSCH-VPN01 | Good | 21900544 | 2195456 | 10 | 4 |
Balsall | BSHC | SD-WAN | BSCH-VPN02 | Good | 21908744 | 2195676 | 5 | 5 |
Bravo | BRVO | SD-WAN | BSCH-VPN01 | Good | 5192 | 4820 | 6 | 1 |
Bravo | BRVO | SD-WAN | BSCH-VPN02 | Bad | 0 | 0 | 0 | 0 |
I am relying on CustomProperties (SWCP) for Site and DeviceType Columns along with the CustomPollerStatusOnNodeTabular tables which include the VPN Overlay stats;
SELECT NCP.SWCP_Site As [Site], SWN.nodeName As [Node], NCP.SWCP_DeviceType As [DeviceType], CPT.DisplayName, CPT.AssignmentName, CPT.Status, CPT.CustomPollerID
FROM orion.Nodes SWN
INNER JOIN
Orion.NodesCustomProperties NCP
ON
SWN.NodeID = NCP.NodeID
--WHERE NCP.SWCP_DeviceType = 'SD-WAN'
--ORDER BY NCP.SWCP_Site
INNER JOIN
Orion.NPM.CustomPollerStatusOnNodeTabular CPT
ON
NCP.NodeID = CPT.NodeID
WHERE NCP.SWCP_Site <> 'Azure'
