Hi Friends,
We are not able to login Orion web-console and getting session time out error while trying to login.Every two days i am getting this error.Can anyone please help me.
"Transaction log space full" can cause web-console login issue in solarwinds Orion?.
If your transaction log is full, that can block you from logging in with domain accounts.
The database can't update with the domain details and will block login. You should be able to log in with local Orion accounts but the transaction log full is a more serious issue that you should investigate (as @sum_giais said).
If you're using FULL recovery model for the database, you should be backing up the database frequently to reduce the size of the transaction log.
Hi All,
Thanks for your consideration and reply.
Please let me know if anything needs to be done from Orion side for this transaction log or database team needs to take care of it?
