Hi All,
My first post and an Orion Noob. NPN v12.0.15390090 Have had a look for this solution in the search and seems to be an issue from many moons ago, either it is now fixed or everyone has resided to the fact there is no fix and no longer ask.
We have a lot of sites (some small, some large) with a number of Routers/Switches and other devices per site. When I select a node from a particular site, I would like a visual representation of the network topology at that site. Whenever I customise the MAP diagram and select the map for the site location it seems to be a global change in that all nodes will get the diagram I just selected.
I guess a work-around would be for me to drill in to the map and work my way down the nested maps until I reach the specific digram. Seems a bit naff. Is there a way to resolve or a "better" solution?
cheers
Dave
