Hello everyone,
i've created a new CP with Name "Network_Node_NAC" for Nodes:
As i did this several times before, i would now like to change the values for each Node on this CP. So i marked it an click on "Werte anzeigen/bearbeiten" (View/Edit Values). In the following view normaly the columns "Description/Caption", "IP-Address" and the marked CP from the view before appears. But as you can see, the CP is not there. If i click on one existing column to add another one the new created CP "Network_Node_NAC" is not present.
I cleaned up the Database via "Database Maintenance", restart the IIS Webservice and restart the SW services. I also forced a failover on our HA pool but nothing worked. I still can't see the CP for updating values.
On the Database itself i can see the new CP
Has anybody an idea what the problem is?
Thanks a lot
