Hello, I'm working on a new SolarWinds implementation with many of their products in scope. I have information, but it's a bit limited for port communication via pollers and servers. I've based my firewall changes on the SolarWinds Port Requirements, but I'm being asked for more specific reasoning.
Could someone please direct me to another doc/URL that has some info below or is there anyone that can answer for me?
I've inherited the project that they've been attempting for a few years, so any guidance is immensely appreciated.
Thank you!
Why do SolarWinds Polling Servers need to establish communication to End Hosts for Ports that are typically reserved for Server Services.
- For UDP or TCP 53, will the SolarWinds Polling Servers be requesting DNS services from the End Hosts?
- For UDP 123, will the SolarWinds Polling Servers be requesting NTP services from the End Hosts?
- For UDP 162, will the SolarWinds Polling Servers be sending SNMP Traps to the End Hosts?
- For UDP or TCP 389, will the SolarWinds Polling Servers be requesting LDAP services from the End Hosts?
- For TCP 25, will the SolarWinds Polling Servers be requesting SMTP services from the End Hosts?
