Hey everyone,
I'm looking for a way to alert on the condition when a thin access point disappears from the Wireless Controller. I'm not sure if this is possible to get that granular with alerts.
Maybe? I haven't tried it but this is what I would do.
We just add them as ICMP only nodes and use a node down alert to determine when they are offline.
While we do get syslog messages when these go up/down we don't have anything in place to reference these messages back to a master list of access points.
I would like to know how others are working this issue as well?
There's an out-of-the-box alert called Thin AP down. It works a treat for when an AP goes down. But if it stays down for a long time, you don't get an up alert when it comes back online.
I've noticed you've posted this a few times while searching for WLC issues. I believe this behavior is due to this global setting "RemoveDisappearedAPs" being set to default. The default action is for Solarwinds to delete APs from the database once they disappear from a controller. I usually change this setting to not delete them. If you make that change, you will get alerts when your APs return to the controller.
http://YOUR_SERVER/Orion/Admin/AdvancedConfiguration/Global.aspx
RemoveDisappearedAPs - (uncheck to not remove APs)
