Hi All,
I was studying for the exam and was baffled by the answer for one of the questions.
Link:
Success Center
Category: User Management
Question:
2. You need to ensure that an Orion user account can make changes to resources and views as needed.
Which permission will allow the user account to do this with the least amount of privilege?
a. Allow Node Management Rights must be active
b. Allow Admin Rights must be disabled
c. Allow View Customization must be enabled
d. An Account Limitation must be defined
Answer Key:
c.
Why is this wrong?
I was sure b was the best choice since the user would ONLY need both Node management rights(a) and View customization (c)
However, View customization will NOT give you abilities to change the node resources (Already tested this to make sure I wasn't going insane, I'm not
Hopefully the exam questions are more straightforward.
Has anyone taken the NPM exam yet? Any words of encouragement?
Thanks!
