I know this is a really old thread and I hope someone sees this post. I'm trying to to this exact thing on version 9.5. I shut down the NPM service, update the Location and Contact fields with my custom data. At that point the info is confirmed updated in the database. Once I restart the service, these fields get overwritten.
Has anyone worked out a way to do this on version 9.5?
Ditto on Ironmike's request.I monitor about 2000 devices spread over 80 sites. At each site, the switches are housed in one of several TRs. On each switch, I use the snmp-server location field for the site location and then the snmp-server contact field for which technical room its in.In NPM, Nodes are displayed by location, then contact. The problem is that I monitor up and down state of servers at each location. This is done by ICMP only. Now, the node tree's first item is "Unknown" and within it are all the servers. I'd like the server to appear under it's location but keep them as ICMP monitored only.
You cannot retain the data in the fields that are used by Orion to store data collected by SNMP.
For this reason we provide the ability to create custom fields and populate those (you can update many at one time under Manage Nodes).
Unless I am misunderstanding your question, you will need to create a custom property to do this.
On your Orion server in the Solarwinds Orion program group you will see Grouping and Access Control, Custom Property Editor. If you haven't seen it yet I think you will find that it is what you are looking for.
Any custom property you create is also eligible to be used in the Nodes Tree grouping as well. I've seen some clients do very elaborate grouping this way.
Hope that helps.
Ok, I'm cool with that. I do have some custom properties that I will use for this purpose.
With that said, has anyone created any SQL scripts or NPM jobs to read the values in the Orion SNMP fields (Contact and Location) and write them to a custom property? That would solve my problem. At this point I am doing it by hand in the custom property editor.
I'm not a SQL guru so any help with something to do this is much appreciated.
The SQL query should look like this:
update nodes
set xxx = Contact, yyy = Location
xxx will be the name of your custom property field that will hold the information in the Contact field and yyy will be the name of the custom property field that will hold the Location data.
