guys We tranferer solarwinds server and old version data base is standard and a new is express sql.
and running cw show this error.
I see in KB need create a new tada base but this is not rigth. I need to user old data base.
Hey cjfranca did you ensure that the following has been met?
1. Same Orion version installed on new server as compared to the old Orion server
2. The sa account has been granted access to your SolarWindsOrion database You may need to force it if not:
http://stackoverflow.com/questions/7702178/cannot-create-sql-server-database-user-correctly
Thank you janene16 I try this but not work. My partner talk with BDA and he change configuration a user and runngin. after install I will post here the sotluions
