Do I need to uninstall the Wireless Module from 9.1 before I upgrade, since 9.5 has it integrated?
Thanks.
~CJ
I believe if you attempt to upgrade to 9.5 with the Wireless Module still installed we block the install. So to answer your question, I believe you have to uninstall the Wireless Module first.
I decided to test it, and that is right. It stopped the install. It also says my APM is not supported, but I thought I had the most up-to-date version. I'll need to check on that before install, too.
