Is there a setting in MRC to prevent this warning? I did some research and found some info indicating it may be due to MS update KB2592687 which is the Remote Desktop Protocol (RDP) 8.0 update for Windows 7. I uninstalled the update, but I am still getting the warning. I do not get this warning when using MS RDP. I need to start MRC from the command line and login, it starts up and get stuck on this dialog, I tried various cmd line switch settings with no luck.
Thanks for any help in advance.
