Our Solarwinds team has set up Disk alerts at Warning, High, and Critical Thresholds.
From what I am told, they should apply to all disk volumes.
If I look at the Active Alerts, and filter down to volumes and to Critical alerts, I get a listing of a number of active critical disk alerts.
If I run a simple report, asking for all volumes running above the critical alert threshold of 95%, it returns me a listing of all volumes currently running above our critical threshold of 95%, but it is double the size of the Critical Active Alert data.
This tells me that all of my volumes must not be alerting.
If I look at the ones that are not showing on the active alert list, I see that in the box called:
Why does it not show the Warning and Critical Alerts?
All Alerts this Object can trigger (1)
ALL ALERTS
| ALERT NAME | DESCRIPTION | SEVERITY |
| _DiskUtilization_High | Triggered when disk utilization is between 90% and 95% on any device regardless of platform | Serious |
