Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Beta Alerting Engine: Run external Program
Grabowski
I think I found a "bug" in Beta Alerting Engine, SysLog-server and in the SNMP Trap receiver (all new(ish) .net Solarwinds applications:
In the "old"/current alerting engine of Orion NPM I am using this string to launch a local executable (with switches) on events:
cmd /S /C ""d:\Program Files\Zonith\NMSListenerClient1.3\bin\sendAlarm.bat" -t "${Time} - ${NodeName} is ${Status}"" -u ${Location_code} -a ${Relevance}
In the beta alerting engine the Syntax needs to be like this to work:
"d:\Program Files\Zonith\NMSListenerClient1.3\bin\sendAlarm.bat" -t "${Time} - ${NodeName} is ${Status}" -u HOE -a Global,HOE,sm
The differences are very subtle, but it took me ages to figure out why the same string would work in the old SW apps but not in the new ones, so I thought that I may save one of you guys from going through the same thing by posting it here
Also, I found that the auto-refresh of the active alerts window doesn't remove alerts when they change state from "trigger pending" to "reset". Triggered alerts go away fine. If you click the "refresh" button manually, the view is updated correctly. I have reported this to Solarwinds
Lars Grabowski
Global Infrastructure
Chr. Hansen A/S
Currently using:
Cirrus Version 3.0 DL-500 Apr. 2006 (8.3.53)
Orion Application Monitor 7.8.94
Orion Web Engine Version 7.8.133
Orion NPM SLX 7.8.5 March 2006
Alert Manager 8.1.15
Find more posts tagged with
Accepted answers
All comments
There are no accepted answers yet
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
