When I load the web console of my additional Orion poling server, I see the following two errors:
Anyone seen this before?
and the other error is:
Ah, that doesn't look like much fun. Try re-running the configuration wizard with all 3 boxes checked: network, services, web. If that doesn't sort it out, it's time to hit up support.
They look like resources added from the NCM integration module.
Did the install of the integration module on the additional web server complete successfully?
Don't forget that you will also need to copy the security certificate onto the additional web server (http://support.solarwinds.com/kbase/ProblemDetail.cfm?ID=1121).
Dave.
