I need some help. For some reason I feel like this should be completely canned already in Solarwinds so maybe it is. Our NOC views node status and on their view they will only see when a Node is down. In the same way, I want to be able to show them when a Cisco device has a power or fan problem. The table should be very simple (Node, power supply (if power supply 1 or 2), status). It should only show if there is an issue. Otherwise, the table should be blank.
I've worked some with the UnDP pollers and even imported one from Thwack. This is great, but I can't seem to figure out how to present the data on the NOC view. If anyone can assist or point me in the direction of a tutorial that would be great. Keep in mind, I'm completely new to Solarwinds so I'll need help from the ground up.
