1. What’s the best upgrade path from 12.1 to current on npm? I just took over a new environment that needs lots of work. Right now I’m just auditing and trying to make decisions on on best ways to deploy a better system and design.
2. Theoretical limits. I know SolarWinds has a soft cap of 12,000 elements per node. All dependent on several factors. But how would you go about getting the best return of investment on all the hardware and license you already have? For instance I have a beefed up server. I throw everything at it and it barely breaks a sweat but software wise I get close to 12 k and SolarWinds likes to whine about it. Would license stacking take care of this issue to basically make use of the hardware assigned to do the polling?
3. This environment is extremely heavy on SAM. 90% of all monitoring is software monitoring. I know Sam has its limits too. How can I get Sam to respond correctly to high heavy loads? For example 13 pollers and all with an average of 12k components each being monitored.
The whole point here is consolidation into the smallest amount of machines I need to make it work. I don’t want to have an expansive environment all because the software is capped. This is the part of forecasting that always gets me frustrated because I want to go over kill on specs but what’s the use if the software can’t handle it? See what I mean?
As I said I’m auditing and creating reports to understand what’s the main purpose this environment will be used for. Then working on resolving all issues found and upgrade as needed.
Ipsla and netflow aren’t even being used due to the modules currently being handicapped. Site performs is down the drain. And I’ve been task of turning this around to give it value and purpose.
any help suggestions, tips, tricks, lottery numbers...all appreciated haha
