I just added some more Geist Environmental Monitors to NPM and noticed that some of them are giving back crazy values. I have confirmed that the MIBs listed on the Geist MIB list match with the temperature MIB that we have set in NPM.
Here is a screenshot of the resource. 73 and 78 are reporting the temperature correctly.
I was digging a little deeper and loaded up the UDP application and tried testing the MIB against some of the nodes that were and weren't reporting correctly. When I tested the nodes with the crazy values, I got a "The OID is not supported" message. I have checked and found that the firmware between working and non-working nodes is the same. They are also the same model number. Any ideas on what else I can do to check or how to get them to read the OID?
