How to connect the different database(SolarWindsOrion) for per PE?
nowadays, installing the PE , i want conneting the Createing Datebase(citySolarWindsOrion)
How can i do it ?
thanks,
So, all PEs will have to use the same database. Why do you want to create separate databases?
By PE, do you mean an Additional Polling Engine? The polling engine writes to the same database as the primary Orion server. Polling Engines do not have their own database.
yeah. there are 5 PEs. i want create different database for per PE.
there are 11 Citys totally. it will be huge of the data, so i want to separate databasees.
