Hello,
I'm trying to execute a homemade script (coded in asp) but I'm not too sure how to integrate it into the web view Node Details. Basically, this script will perform some SQL quieries to db and present results after some filtering.
Is there any way to add an ASP script into a 'resource' module of the Node Detail page? It seems that the HTML resource do allow only HTML code.
Many thanks,
Sylvain
