I'm a new user and cant seem to locate specific upgrade instructions on what all to do to get from NPM 10.1.3 to 10.2. Could someone reply with a link to the instructions ? Thanks in advance.
RLumsden,
Do you have any other Orion modules (e.g. NTA, NCM, IPAM, IP SLA)? If not, it's a straight execution of the installer, as 10.1.3 upgrades to 10.2 directly.
HTH,
There should also be Upgrade Instructions in your Customer Portal.
Sure enough. I found it once I got to the download screen. Thanks all.
