I have a number of views created with "custom object resource" charts added to show bandwidth for various interfaces in our environment. On these charts I typically set the "default zoom range" to 24 hours and the "amount of historical data to load" to 7 days and this works nicely.
For various reasons I have started looking into replacing the "custom object resource" charts with "custom chart" instead. This seems to be a more elegant solution, however, I have been unable to figure out how to set the default zoom range on these custom charts. If I set the time period value to 7 days the chart shows all 7 days by default. It is possible to adjust the slider bar at the bottom of the chart after it loads to show a smaller amount, but this has to be done each time.
Is there a way to add a default zoom range to the custom chart, similar to what is available on the custom object resource? I am currently using NPM version 10.0.14393.0.
Thanks in advance!
Scott
