having problem in solarwinds ,its not showing detail information of down nodes untill we restart the whole services .pls help regarding this issue .
regards
This probably needs to be moved to the NPM subforum.
Now, which services must be restarted before you can see detail information on down nodes ?
Can you provide a screenshot of where you are seeing the issue ?
Without more info, we'll be challenged to help you. Definitely open a support case with Solarwinds via telephone--and at the same time see if we in the Thwack forum can help. Think of it as a competition--who gets you the answers you need faster. ;^)
Hi .
Thanks to reply, I am sending you screenshot do needful help .
Waiting for your reply.
Regards
Tahir .
There are some possible solutions here: Unexpected Website Error: Insufficient winsock resources available..
This link has a helpful title that immediately provides the symptoms...as such, it was helpful to immediately find a possible solution via forum search Network Performance Monitor
Best way to find possible solutions is thwack the error mesasge you are getting. If you still cannot find it best thing to do is call solarwinds support. You may want to run a diagnostic collection and upload it to them with the case number using SolarWinds.Net | Powered By LeapFILE I normally do that right after the ticket is opened so that when it gets assigned a tech they can start working on it right away instead of emailing me for more information and that file.
