Does Orion require that a SQL agent be running in order to perform daily maintenance procedures?
Yes, this Agent is used to allow Orion DB Manager to perfrom the Schedule Backups.
Thanks for the reply, Mark.
Is that the only type of maintenance that the SQL agent controls?
Does the agent have anything to do with the nightly data summarization procedures?
No, that is controlled separately.
