I’ve found a flaw in the GUI. The footer hides the command prompt which makes this tool unusable. You can clearly see in the attached screen capture of my SSH session to a switch that the bottom of the session is hidden from view by the Footer. Is there a way to fix this?
Jonathan, if the resize does not help, try changing the scale factor.
I personally use 3 full HD monitors, each 1920x1080 and Solar-PuTTY works great.
I'm disappointed that I've not had a single reply from Solarwinds on this. Look at the attached image and see for yourselves that your putty app is unusable.
Let me share this with engineering team and dig into further and come back to you.
OK exchanged notes with engineering and we can duplicate, but only in specific conditions. Can you tell me what your resolution is set to on that machine? Is it a normal laptop or something like a Surface like tablet? If you resize the window, is anything different?
It's my work PC with triple monitors running at 5760 x 1080
