Orion SLX 9.1 SP3, monitoring 750 nodes and 7263 interfaces. Win 2003 Server R2, Sp2. Database is on MS SQL Server 2005 server on Windows 2008 Server Sp1
Orion can find the nodes using SNMP 2c community name, I can select resources. However, the node isn't found in the nodes list -- even is not sorted -- and isn't found using the find feature. Any ideas?
