I am running Orion NPM 8.1 on a Windows server and just loaded Toolset V10 and now i can not seem to get the Orion NPM to connect to my polling engine? Suggestions?
d-moore - Our great QA folks have been re-testing the issue, and one was able to recreate a conflict which you might be experiencing.
If you are getting an error when opening System Manager, try the following:
HTH,
Greg
DTGEDS - There shouldn't be any issues that I am aware of... I would look to make sure the Orion service is running and there are no firewall issues (if the engine is on a different box).
You can also try running the Orion Config Wizard to reset the connection params...
I have the EXACT same problem with OPM 8.51.
Since the upgrade on my OPM server, I can't connect to my polling agents since upgrade. Ticket # Case #89228 has been opened.
Fixed!!! Way to go QA Dept!!!
Yes , Greg that fixed my issue as well. Thanks for all the great help.
