how can i get APC ups data specially battery percentage and alerts on battery percentage in orion 11.5 kindly mention configuring custom alerts step by step for ups data "battery capacity " like battery is 100% or 95%
Hi Nasir,
You have to use UnDP in order to poll the needed OID for Battery, Voltage or whatever you want, then you have to chose wheter to use a report or triggered alerts.
Have a look here, you will find the UnDP file and some experienced example for reports and alerts:
https://thwack.solarwinds.com/docs/DOC-129094#start=50
APC - Replace Batteries According to Age Report
Issue with APC upsAdvBatteryCapacity value
Regards.
Salah
thats good i achieved something from it . thanks
Happy to know about that
