I have custom icons I'm using in mapmaker. when the interface is shutdown, it fills in the "background" with red.
This leads to much confusion for my Ops center as RED is usually down/issue.
Anyone know of a way to remedy this? Thanks.
don't use the tri-color overlay, instead try the X overlay, but you still might have the same issue.
That is an option. Thanks for the reply.
