I noticed on your demo site that the Node Management page show Node and Interface custom property columns.
How do you get those to display?
patriot,
If you log in with a user that has rights to change the view, you can add columns by clicking on the two great than >> symbols on the far right hand side of the column headers. Just click the >> and select the columns you want displayed.
Hope this helps!
Maybe I need to open a ticket with SW then, because I am logged in with View Customization rights and there are no >> on the right end of the columns of the Manage Nodes page.
Yeah, you might need to ask SW. I even see them when using an account without View Customization rights. It kind of looks like all you need are Manage Node rights. Here is a screenshot showing you where they should be. Not sure why you can't see them. Maybe someone from SW can tell us what might be causing you not to see them.
