Adding addtional rows to the Advance Node Details and including content constructed out of custom properties:
eg. <tr>
<td class="Property" width="10"> </td>
<td class="PropertyHeader">Directions</td>
<td class="Property"> </td>
<td class="Property"><a href=""]"))%>,+<%#MakeBreakableString(Eval("ObjectProperties[\"Long\"]"))%>"">maps.google.com/maps target = "_blank">Directions</a></td>
I'm trying to do something similar with the Nodes With Problems resource. I've successfully added a clickable link to open a ticket, however it appears that using this same strategy as above to access a custom property does not work correctly, while using predefined variables in the Nodes table does.
I'm using the 'NodeID' to build the open ticket URL. I want to link the M icon to the URL of the view that the Node is on. I have a column that has the numeric value of the view that the node sits on.
<td class="Property"><a href=""]"))%>"">server/.../NodeEventForm.aspx title="Open Ticket" target = "_blank"><img src="server/.../a>
</td>
^^ This works correctly, however when I replace NodeID with Map (the column with the number of the view) I get the following error.
The "Nodes with Problems" resource threw an exception..
Exception has been thrown by the target of an invocation.
This is what the HTML looks like:
<td class="Property"><a href=""]"))%>"">server/.../SummaryView.aspx title="View Map" target = "_blank"><img
src="server/.../td>
</td>
Anyone know how I can access the custom property so that the linke builds properly
