NPM does not show any change on interface if it has no traffic on it. I want to to show any change on realtime as solarwinds Engineer tool set do. I'm using NPM version 10.6.1.
thanks,
Have you looked at Toolset v11?
Engineer's Toolset v11 is generally available
Holy,
thnx for reply. Is this tool integrated in NPM or I'll have to purchase it separately? right now I'm using NPM version 10.6.1.
It is Toolset web integration with Orion. So, you will need NPM and Toolset v11
thnx for update,
If you can please clarify it more, I need to purchase toolset v11 ?
HolyGuacamole is correct, if you want to do realtime views you are going to need Engineer's Toolset, specifically this tool Interface Monitor Tool | SolarWinds. The Engineer's Toolset is a collection of tools and, most recently, was changed so that you could integrate the toolset with your NPM instance. There is a great YouTube video on it in the link that HolyGuacamole posted --- but here is the direct link. https://www.youtube.com/watch?v=YE2rKHeqlAA
For real-time interface utilization you definitely need to purchase the Engineer's Toolset. NPM data collection intervals can be as frequent as 1 minute though I highly recommend that you be very selective about the number of devices that you poll that frequently as it can have an adverse affect on your Solarwinds instance as well as your target device.
Good luck!
