I've added the UnDP Status item to my Node Details view and set it to hide itself for devices that it doesn't apply to, but it stubbornly refuses to hide. Any hints on how to get it to behave?
Right click on the universal device poller and then web display. Check do not show this if no assigned. Thats how i have mine setup and i verified it does not show up on node details of other nodes it is not set up in. A question to you as well. Do you know how to choose what pollers you want added to UDP status and to put them in some sort of order?
Hi there Jason.
I don't have a problem applying pollers to nodes/interfaces. The problem I had was that I added the "UnDP Status" item to Node Details view, and it was showing up for nodes that had no pollers attached to them despite me setting it to hide itself when it didn't apply. This problem seems to have resolved itself between then and now, however. I'm not sure which SP did it, though.
Edit: Oh, and I'm not sure how to answer your question. I'm sorry.
