Is it possible to filter the All Applications list in APM using the current value of a custom poller assigned to a node?
For example, would I be able to use CustomPollerStatus.Status ="XXX" as a filter?
That's a great question. Could someone please answer this?
Hi Freeman--
You should definitely be able to do this--there's not inherent limitation that would prevent you.
M
Thank you Marie, but can you suggest the filter syntax that will do this? What variable will correctly designate the custom poller?
Hi Freemen--
I checked with our brilliant developer, Karlo and here are his suggestions:
NOTE: This is an advanced feature and you will be manipulating your database. Loss of data could occur.
Phew, glad that disclaimer's done.
The SQL statement would look something like this:
