Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Upgraded 8.5.1 to 9.1 Issues
netbum
Maybe this might help someone who is thinking about upgrading.
I upgraded my NPM from 8.5.1 to 9.1. Since that time several things have been happening. These are listed below. Also I built a case with support.
My question is the fix seems pretty drastic and does anyone know if when I put my maps and reports back will everything I have built come back? I just don't want to loose everything I have built.
1. The solarwinds Orion Module Engine is going up and down.
2. We are getting runtime 2.0 errors continuously in the event logs. I do have Net 3.5 loaded.
3. On the web site it comes up but at the very bottom it still shows it is running on Orion NMP version 8.5.1
4. Custom MIB poller service will not start.
I deinstalled APM to get NMP loaded so it is currently not installed.
Support Response:
Go ahead go into the Program Files> Solarwinds> Orion and save the maps
and reports folder to the desktop. Then uninstall Orion and all modules.
Then delete the solarwinds folder out of the Program Files Folder. Then
start the installation process over again. You will not need to
reinstall the licenses.
Find more posts tagged with
Accepted answers
All comments
FormerMember
This is a common practice for customers whose install gets blanked-up. It's not drastic.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
