We are not able to get alerts thru basic alerts option even same is working fine thru advance alerts. Please suggest what parametrs I can check to get same active again?
Rgds
Manish
Is there a specific reason you need to use basic alerts? Generally, we recommend Advanced Alerts, as they are more flexible.
What kind of alert are you trying to configure?
Actually, we have approx 200 interfaces to monitor including LAN & WAN & we want to get only WAN alerts on our mobile (Handy) in case of absense in offce, if we select advance alert then we will get alerts for all interfaces & otherwise we have cofgiure all WAN interfaces one by one which means approx 70-80 seperate alerts wll be confirgured, this will be a big exercise to do.
Please guide if possible..
and while configuring it thru Basic alert, we have option to select interfaces for which we need alerts. That becomes easy to categories interfaces.
It is possible to relatively quickly apply a custom property to multiple interfaces across multiple nodes using Node Management in the Web Console.
You can now either apply custom property values to your interfaces in the Custom Property Editor by clicking Interfaces and then right-click copy-pasting values for appropriate interfaces or you can complete the following procedure to apply values using Node Management in the web console.
