Hello team,
Could you please tell me if it is possible to make Dashboard that should be configurable and adjustable to meet current needs such as top 10 switches with high network utilization or based on ports using NPM
What you want is called a "View" in solarwinds. you can configure those the way you need them.
so can we customise based on switches also - top 10 switches with high network utilization ?
There are "Top10 Widgets" you can add to your view, and you can filter the views based on Properties.
Hello Rastogi,
Yes there is an option to configure the same.
Would it possible to drill down the report to identify the specific network port(s) performance ?
I haven't worked on it. But if I were to then i would suggest you to try below steps.
