i.e. when i have created an PortChannel on a Cisco device, i run the rediscover and can select the newly discovered interfaces.
When i delete the Channel again in the device, i can rediscover the interface and it is gone.
But when i look in the Interface-overview the obsolete interfaces are still present.
With the old "Node Manager" i was able to select the Interfaces and delete them, but i can't find any similar option in the entities manager.
Not only channels have this problem, also when you insert and remove linecards.
