OK.... I use the web interface for Orion for a lot of presentation about our network. Prior to the upgrade to V9.5 I was able to add some color to the network map objects so these maps would be a little more appealing. I have a lot of icons that I replace some of the default network map objects with because they have color and they look good on the maps. with the move to V9.5 I found I lost a lot of those map objects.
Is there a way i can import some of my color network objects back into the network atlas?
