Is there a way to see how much storage an individual node is responsible for in LEM? If not, how do you estimate storage requirements when looking to add devices?
Also, there was a white paper put up on solarwinds.com a while back about estimating log generation, where some loose guidelines were given - registration required: Estimating Log Generation for Security Infor...
LEM is also mentioned in this SolarWinds Labs episode: [VIDEO] SolarWinds Lab #17: Too Small or Just Right? Rightsizing Your SolarWinds Installation
I think the closest you can get would be to check out some of the "Database Maintenance" reports in LEM Reports. You might find some interesting statistics there.
Thanks! I have been using the Database Maintenance reports but they only show the log size as a whole, I can't drill down to a single device. Thanks for the link to the whitepaper, that will be helpful!
