I need to have a box that opens up in Atlas. Something like a comment in Visio. This would be used for detailed maps that would include information such as STP priority, OSPF or BGP info......
Any ideas?
Thank you
This would be beyond current tooltip functionality? Perhaps using CP values?
Actually I wasn't thinking of tooltips, but as a function of the Atlas itself. Similar to adding a rollover comment box in Visio.
I was trying to accomplish this via custom pollers but then realized that the Atlas doesn't support tabular pollers. I have a list of about 10 things I would like to see on each node and a rollover comment box would work perfectly. I say a rollover box because placing that much info on a detailed network drawing would cause the map to get very crowded.
I was able to add an OSPF router ID, but this seemed kind of busy. I only need the current value not all the other stuff in the box.
Got it. I don't believe we have a good solution at the moment. If we did have this capability, would you be OK with purely read-only, or want the ability to add "notes' as well?
Personally, I would only want users with access to Atlas to be able to modify them.
